我正在使用MC56F8245,遇到一些问题。
1,674 次查看
liuzhen
我的PWM模块中断可以正常工作,且电路连接也是好的,但是在PWM的输出口测不到波形。下面是我的具体配置过程和测试代码。希望能尽快得到解决!
标记 (1)
1,445 次查看
xiangjun_rong
Hi,刘振,
I attach an example which use Init_eFlexPWM beans, but it does not use PWM_MC beans. Regarding your question, pls check if you have configured the GPIO pin as peripheral pin by setting the corresponding bit in GPIOx_PER. Pls check if you have enabled the PWM clock by setting the SIM_PCE2 register.
If you can not output PWM signals, pls update the community.
XiangJun Rong
1,445 次查看
liuzhen
没有看到例子啊
1,445 次查看
liuzhen
不好意思啊,找到了
