Compiler options
Compiler options
Buerger
for a student research project, I should write a time optimised code for a 5282 with the NetBurner IDE (GCC). Concerning that I would like to have a look at the assembly file, but my problem is that I dont really know how (or better where) to generate that. I cant choose the compiler options menu, so maybe I have to change something in a make file, but I dont know.
So if you know a little bit more than me, please let me know.
Jens Buerger
mnorman
It sounds like you want to generate assembly listing files.  You will need to add something like this to your compilation rules:
gcc -Wa,-ahlns=name.lst ...
You'll have to google for more details :smileyhappy:
