I'm not familiar with the board, but the since the error message is a complaint about
a low supply voltage, possibly it's worth a try to check. Have a look at the board,
locate the flash memory. Power supply is usually one of the pins at the outer end
of the pin row (if you want to know for sure, google for the chips datasheet) and check
the voltage (usually 3.3V) . If it is too low, you got a hardware defect and can possibly get replacement on warranty.
Greetz - Matt
