How to convert .elf file to .S19 format
Search instead for
Anamika
Hi All,
I am trying to find out how to convert my .elf file to .S19 format???
Cheers,
Anamika
Anamika
Never Mind. I got it.
HarlanRosenthal
Please post how you resolved this, because your title caught my interest.  Was this just a matter of turning on S-record generation in the project settings?
My issue is converting S-records to .bin . . .
bigmac
Specialist III
Hello Harlan,
If you do an Internet search, you should be able to find utility programs to do this.  One such utility would be MOT2BIN.
Mac
BlackNight
CodeWarrior comes for free with a conversion utility as well (it converts to multiple formats, is as well able to combine .s19 files, etc). It runs as standalone utility too. Have a look at the prog\burner.exe. You can run it with a GUI or using a command line interface. See as well Help\pdf\manual_burner.pdf or how it is used in Codewarrior projects (it can use .bbl (batch burner language) input files.
Erich
