i need someone to recomend me for a BDM tool for CW V3.0
4,600 次查看
yshmuly
im tired of that OSBDM and looking for something up to $100
USB is prefered an that will be compatible with codewarrior v3.0
and as much as can MCU's and common one
5 回复数
724 次查看
eckhard
I used v3.1 and just upgraded to v5.0.
So for now i use both versions, but v5.0 seems to be fine.
Eckhard
724 次查看
peg
Senior Contributor IV
I have only used it with V5 because I understood you needed V5 to be able to use the "set gdi" command. So I haven't tried any lower versions. If I get a chance I will try it with V3.1. But I don't have (or want to download) V3.0.
BR Peg
724 次查看
yshmuly
by the way what version of codewarrior do use?
724 次查看
yshmuly
i used the schematics published on this forum but changed the smd with regular parts. the usb flashing wasnt succeded and i did it with mon08 (wich i had to build). after programming it still didnt work so i figured some resistors are not needed. and now somties it work (partially) and sometimes not and i dont want to spend more time with it. it is not well implemented in CW it looks like a patch on it. but thid is only my experience with it maby someone had different.
but now nobody will answer my question (about the BDM in the firs threde)
724 次查看
eckhard
I´am going to build an OSBDM too, whats yor problem with it. Could you please explain whats wrong with OSBDM for you.
Eckhard
