Place a function on a fix adress
ajn
Is there a pragma or equal that I can use to place a function on a fix adress. I need to place the function _startup() on a fix adress. The processor I use is MC9S08GT32, and the copiler is Codewarrior.
Ake
fabio
Hi Ake,
I think that one possible way is to create a new code segment (in the .PRM file) and use the #pragma CODE_SEG to instruct the compiler to store the function in that segment.
