Illegal redefination of label
2,530件の閲覧回数
muskut
hi all,
I have a problem but I cannot find what the wrong is. I determined 2 subroutine programs. They are;
sub1:
mov #11, var1
rts
sub2:
mov #12, var1
rts
when I make the program, an error seems which is "Illegal redefination of label" and the arrow of the compiler is focusing the second subroutine's "rts" line. I dont understand what it the problem? I am using rs08 mcu.
2 返答(返信)
1,000件の閲覧回数
CrasyCat
Specialist III
Hello
Do you have at least a space or a tab in front of your RS08 assembler instructions?
Usually it is common practice over macro-assembler language to have only labels starting on column 1.
CrasyCat
1,000件の閲覧回数
muskut
You are right. The problem was the tab spaces. I have been programming about for 6 years and I have never seen like this problem :smileyhappy: interesting. Thank you so much.
