MPL3115A2R1 marking information
barleyli
It gets MPL3115A2R1 and finds that the part with below marking,
Marking:   M3PR
                 FZ0D
Would you help to advise whether the above marking is correct?
Also what is the meaning of this marking?
Thanks a lot.
TomasVaverka
Hi Barley,
Yes, the above marking is correct.
The first line contains both part number code and assembly line code information.
The second line contains both date code and lot code information.
Tomas
