Where is the reference design of imx6 solo?
翔李
HI,
I am going to design a car-application production on imx6 solo,there is no imx6 solo sch and pcb on nxp's web,but has imx6 soloX. So,If I use imx6 solo,Can I usr the sch and pcb of imx6solo X?
Thanks.
Yuri
  Please refer to Table 8-20 (Serial ROM Boot eFUSE Descriptions) of i.MX6 S/DL RM.
Also, please use Table 8-23 (SPI IOMUX Pin Configuration) regarding pins using - looks
like - is OK in Your case. Note, QSPI is not supported by i.MX6 S/DL.
Yuri.
Yuri
  You may use i.MX6 DL design as base
https://www.nxp.com/webapp/Download?colCode=SABRE-AI-BASE-BOARD&appType=license&Parent_nodeId=133780...
https://www.nxp.com/webapp/Download?colCode=SABRE_AI_DESIGNFILES_CPU2&appType=license&Parent_nodeId=...
Summary Page :
SABRE|Automotive-Infotainment|i.MX6|NXP
  Also, please refer to app note AN4397 (Common Hardware Design for i.MX 6Dual/6Quad and i.MX 6Solo/6DualLite)
http://www.nxp.com/assets/documents/data/en/application-notes/AN4397.pdf
Yuri
翔李
thanks.
where is sch migration of IMX6 series,especial about imx6 solo and duallite?
Is it last email AN4397?
Yuri
   because of pin-to-pin compatibility - no need for migration : just common design is available.
Yuri.
翔李
But I already design a production on IMX6Q ,Now I am going to design a new board on imx6 solo,So,Is it pin-to-pin compatibility between imx6Q and imx6 solo on sch and pcb?
What is the difference between Q and solo in sch and pcb design?
Yuri
Please follow the app note  AN4397.
~Yuri.
翔李
I am not sure Which sch for me to refer for designing imx6 solo is the best choice?
1:what is the difference between SCH-28605_B1.DSN and SCH-28605_B1_16P2 in 《SABRE_AI_DESIGNFILES_CPU2.zip》?Which sch, for me to refer for designing imx6 solo? Also in other SABRE zip.
2:what is the difference between SABRE_AI_DESIGNFILES.zip and SABRE_AI_DESIGNFILES_CPU2.zip?   SABRE-AI-BASE_BOARD.zip and SABRE-AI-BASEBOARD,zip?
also,what is the difference between 《SABRE-AI-DUALLITE-CPU2.zip》and 《SABRE_AI_DESIGNFILES_CPU2....SABRE_AI_DualLite_CPU2》?
Yuri
Please look at my comments below.
1.
  File SCH-28605_B1_16P2 is in so called OrCad 16.2 format - it is more suitable
for importing for other CADS.
2.
SABRE_AI_DESIGNFILES is based on MX6 Quad Plus
SABRE_AI_DESIGNFILES_CPU2 - on MX6 Quad and Duallite
Yuri.
翔李
THANKS.
What's more,I did not find the boot mode list of imx6solo,where is the detail boot mode setting list,EIM_XXXX?
I am going to boot from 32MBYTE-SPI NOR FALSH orTFcard-SD2.
Yuri
Yuri.
翔李
Thanks.
