Stack Size in TASK_TEMPLATE_STRUCT
csmgsarma
Hi List,
1. What is the need for stack size in this structure? Some RTOS flavors don't need this parameter.
2. How can a programmer choose his stack size optimally?
3. How can the stack usage be checked?
Sarma
Tags (2)
danielchen
Hi Sarma:
1)  A proper configuration of the stack is essential to your system stability and reliability. If the stack size is too small, stack pointer might be moved out of the stack area thus an overflow situation occurs. In this case, the executing code could write to the area allocated  below the stack and lead to a serious runtime failure like overwritten variables, wild pointers, courrupted retrun address etc. On the other hand, setting the stack size too large means a waster of RAM resource which could be very limited in MCU-base embedded system.
I think you can google more for this topic.
2 & 3),MQX provided a tool , TAD (Task Aware Debugger) can analyze the stack usage.
Please read the below document for more details
C:\Freescale\Freescale_MQX_4_2\doc\tools\cw\MQX_RuntimeTAD_Getting_Started.pdf
please also check this thread for how to determine the task size
How to determine the task Stack size
Best Regards
danielchen
Hi Sarma:
Best Regards
