Hello all
I have out custom board with 2 lvds output
while I try to get these ports work with separate mode, the second port failed
and with dual-mode setting in dts file , two panel work ok,no hardware issure
And from kernel 3.14.28, double lvds issue
I dont get the information about how to set the dts file and bootcmd
and my bootcommand is
setenv bootargs 'console=ttymxc1,115200 root=/dev/mmcblk2p1 rootwait rw video=mxcfb0:dev=ldb,if=RGB24,bpp=32 video=mxcfb1:dev=ldb,if=RGB24,bpp=32'
and I got an error of
ldb ldb.13: LVDS channel1 is already used
in kernel dmesg log .
my dts file config is
&ldb {
status = "okay";
lvds-channel@0 {
crtc = "ipu1-di0";
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
primary;
status = "okay";
display-timings {
native-mode = <&timing0>;
timing0: at080tn64 {
clock-frequency = <51200000>;
hactive = <1024>;
vactive = <600>;
hback-porch = <50>;
hfront-porch = <220>;
vback-porch = <23>;
vfront-porch = <12>;
hsync-len = <50>;
vsync-len = <5>;
lvds-channel@1 {
crtc = "ipu2-di1";
fsl,data-width = <18>;
status = "okay";
display-timings {
native-mode = <&timing1>;
timing1: at080tn64 {
hactive = <1024>;
vactive = <600>;
hback-porch = <50>;
vback-porch = <23>;
hsync-len = <50>;
vsync-len = <5>;
Can you give me some suggest of how to set dual lvds out with separate mode in kernel 3.14.28 ?
regards
xiongwei
