Hi Team,
I've implemented creating a new partition on Android, and now I want to create a partition on Yocto.How to do it?
Thanks in advance.
Hi Rit Wang:
Think you for your reply.
I had modified device/fsl/common/partition/device-partitions-7GB.bpt tto add a new partition in imx8mq android8,but I can' t find out this file in yocto BSP.
Which flash are you using, emmc or SD card?
Hello Rita Wang:
I'm using emmc.
In linux BSP you can see the https://community.nxp.com/docs/DOC-343187
It's the same method with the android BSP
