Description | Bootloader over USB |
Component | BootLoaderUSB.PEupd |
Dependencies | Wait, BootLoaderUSB, S19 |
This component is based on the Freescale Application Note AN3748.
The copyright notice of the original file is provided below:
* (c) copyright Freescale Semiconductor China Ltd. 2008
* ALL RIGHTS RESERVED
* File Name: SCSI_Process.C
* Description: This file is to handle SCSI command
* Assembler: Codewarrior for HC(S)08 V6.2
* Version: 2.3
* Author: Patrick Yang
* UPDATED HISTORY:
* REV YYYY.MM.DD AUTHOR DESCRIPTION OF CHANGE
* 1.0 2008.01.02 Patrick Yang Initial version
* 2.0 2008.06.10 Derek Snell Modified to work with USB MSD bootloader
* 2.1 2008.08.15 Derek Snell Fixed SCSI issue to work with non-XP OSs
* 2.2 2008.08.25 Derek Snell Renamed SCSI Inquiry to "Freescale USB Bootloader"
* Stopped accepting write data from host after successful S19 transfer
/* Freescale is not obligated to provide any support, upgrades or new */
/* releases of the Software. Freescale may make changes to the Software at */
/* any time, without any obligation to notify or provide updated versions of */
/* the Software to you. Freescale expressly disclaims any warranty for the */
/* Software. The Software is provided as is, without warranty of any kind, */
/* either express or implied, including, without limitation, the implied */
/* warranties of merchantability, fitness for a particular purpose, or */
/* non-infringement. You assume the entire risk arising out of the use or */
/* performance of the Software, or any systems you design using the software */
/* (if any). Nothing may be construed as a warranty or representation by */
/* Freescale that the Software or any derivative work developed with or */
/* incorporating the Software will be free from infringement of the */
/* intellectual property rights of third parties. In no event will Freescale */
/* be liable, whether in contract, tort, or otherwise, for any incidental, */
/* special, indirect, consequential or punitive damages, including, but not */
/* limited to, damages for any loss of use, loss of time, inconvenience, */
/* commercial loss, or lost profits, savings, or revenues to the full extent */
/* such may be disclaimed by law. The Software is not fault tolerant and is */
/* not designed, manufactured or intended by Freescale for incorporation */
/* into products intended for use or resale in on-line control equipment in */
/* hazardous, dangerous to life or potentially life-threatening environments */
/* requiring fail-safe performance, such as in the operation of nuclear */
/* facilities, aircraft navigation or communication systems, air traffic */
/* control, direct life support machines or weapons systems, in which the */
/* failure of products could lead directly to death, personal injury or */
/* severe physical or environmental damage (High Risk Activities). You */
/* specifically represent and warrant that you will not use the Software or */
/* any derivative work of the Software for High Risk Activities. */
/* Freescale and the Freescale logos are registered trademarks of Freescale */
/* Semiconductor Inc. */
