Relocating Code and Data Using the MCUXpresso IDE
Document created by Alice_Yang Employee on Sep 1, 2017Last modified by ebiz_ws_prod on Aug 6, 2018
Version 15Show Document
  • View in full screen mode
This document provides some sample codes and steps for relocating Code and Data into RAM/FLASH. Please look at them with projects in attachment. It is based on “MCUXpresso_IDE_User_Guide.pdf”, so about the understanding of some macros, you can check on that document.
This document is based on FRDM-K64, MCUXpressoIDE_10.0.2_411. You can use it on other chips too.
1. Introduce the “Memory configuration editor”
2.1. Relocating Data into RAM
2.1 Relocating Code into RAM
2.3 Relocating Code into Flash
3.Reference
12 people found this helpful
Outcomes
