- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
I am doing performance benchmark of CMAC in user space and kernel space. which is the best app for doing this.
when I search, I found crypto dev for user space purpose. but it is not supporting CMAC, only AES operation is supporting.
can I get a documentation of kernel crypto API for doing CMAC operation in kernel space?
So any one help me to find the app or document for doing this...
Kanal
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @kanalgovind,
My understading was that you tried a solution with CAAM black key/blob support.
Is using CAAM secure key mandatory for your use-case ?
To my knowedge the latest kernel version does not implement CMAC acceleration using CAAM.
Only AES CBC/CTR ... implementations. The driver could be easily extended to support CMAC.
For your use-case I recommand using SECO HSM/SHE service.
There is an Application note describing how to write a simple application.
Also you can find API documentation here [2]
[1] https://www.nxp.com/docs/en/application-note/AN12906.pdf
[2] https://github.com/NXP/imx-seco-libs/tree/master/doc
If having a inplementation for Linux Crypto API is a must we can discuss a timeframe to write a PoC code/demo for your use-case.
Maro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @kanalgovind,
Maro
