memcmp fails on RT1060
1,256件の閲覧回数
dh1
Hello
We experience a problem with a call to the memcmp function.
We are using MCUXpresso 11.4.1 and the Redlib library.
Under certain circumstances, the memcmp function returns the wrong result. We debugged by looking at the disassembly, and experienced unexpected behaviour there.
It seems that in the failing cases, the subs r2, #4 instruction is not executed.
Following are screenshots from the debug session, first for the successful case, and then for the failing case.
Successful case
Situation before the SUBS r2, #4
Situation after SUBS r2, #4
This is as expected, r2 has been decremented by 4.
Failing case
This is not expected. r2 stays 0xC, and this seems to be the reason why the memcmp fails.
What could lead to such a failure?
Thanks in advance and regards,
タグ(1)
4 返答(返信)
1,235件の閲覧回数
jeremyzhou
Thanks for your reply and clarification.
In my opinion, to avoid the cache data coherency problem, I'd like to suggest assigning a non-cacheable buffer for the store variables or arrays that will be used as input parameters in the memcmp function, it.
And please refer to the application note to do it.
TIC
1,249件の閲覧回数
jeremyzhou
I was wondering if you can introduce the testing steps of replicating the issue, moreover, please upload the demo project.
TIC
1,241件の閲覧回数
dh1
Hello
Unfortunately, the problem only happens under very specific circumstances and in our full project.
The code was working, until we changed some things in other places of the project. Then suddenly it failed.
This happened to us before, it seems like it could be a problem with pipelining/cache or maybe it is dependent on what address the variables are allocated.
1,153件の閲覧回数
dh1
Hello
It seems we are getting closer to the problem, see results in this thread:
https://community.nxp.com/t5/i-MX-RT/Failure-on-BX-LR-istruction-in-redlib/m-p/1456279
