maximum system clock settings
904 次查看
matthiaspimming
Hello, I'm looking for the maximum system clock settings on the i.MX RT 1050.
I found the Table 18-4 System Clock Frequency Values in chapter 18 on page 694 in the Reference Manual ( (https://www.nxp.com/docs/en/reference-manual/IMXRT1050RM.pdf ).
It says that the maximum frequenzy for IPG_CLK_ROOT for example is 150MHz. But in the example projects it is set to 300MHz. There is no detail descripton of Table 18-4 in the reference manual. What does that mean?
Thanks.
标记 (3)
776 次查看
joanxie
what example project do you mean? could you tell me the detailed project name? let me double check it
