Is there an example for the iMX RT-1060 that uses the analog comparator (ACMP)?
Hi @jgeorge0123,
We don’t have a dedicated acmp example for the RT1060. However, you can find an example code for the RT1160 that could be ported or used as a reference for the acmp driver of the RT1060. You can find this example on the RT1160-EVK SDK, which can be downloaded using the following link: https://mcuxpresso.nxp.com/en/select.
BR,
Edwin.
I think I found the ACMP being used as an interrupt in the example project: evkbmimxrt1060_cmp_interrupt
