i.MXRT1050 EVK - LCD demo - issue with colors
次の代わりに検索
820件の閲覧回数
treto
I'm using Zephyr with i.MXRT1050 EVK and I've got the LCD RK043FN. I've run the demo from the SDK examples and ported it to Zephyr. The demo runs alright, except for the colour palette - the red part is missing or is skewed. Green/blue parts seem to be ok. My guess is that one (or more) of the GPIOs that are needed to transmit the byte with red data is incorrectly configured.
LCD is configured as: pixel format = kELCDIF_PixelFormatXRGB8888, dataBus = kELCDIF_DataBus24Bit. Looking at the pin_mux.c that is included in the demos, it would seem that only data bits 0-15 are enabled for the LCD, but the above configuration is used.
Am I missing something or are the bits configured somewhere else, or bytes are squizzed into the 16 bit data bus?
Lukasz
タグ(1)
2 返答(返信)
542件の閲覧回数
MarcinChelminsk
Hi Łukasz,
not sure if it addressess your issue, but I had similar problem with out-of-the-box demo for emWin (MIMXRT1050-EVK platform, but SDK for EVKB, as suggested in NXP SDK builder). Demo called "evkbimxrt1050_emwin_gui_demo".
Display the same from Rocktech (4.3inch 480x272)
So as you can see, colors are bit NOT OK.
The change I have made is:
file:
emwin_support.h
before:
#define LCD_BITS_PER_PIXEL 8
after:
#define LCD_BITS_PER_PIXEL 32
And seems to be working now. Hope that helps and makes sense!
542件の閲覧回数
CarlosCasillas
Hi Lukasz,
You could double check the format keyword (on the mentioned one, there are four 8s). You could also take a look at Item 3 of Table 9 “Boot configuration” from “Hardware Development Guide for the MIMXRT1050 Processor” regarding multiplexed LCD signals, available on the following link:
https://www.nxp.com/docs/en/user-guide/MIMXRT1050HDUG.pdf
Hope this will be useful for you.
Best regards!
/Carlos
