SDRAM model(W9864G6KH)
ywjack
NXP technical support Hello:
I have a question about SDRAM (W9864G6KH) to consult you. Firstly, there are two ways to initialize SDRAM. One is through call
BOARD_InitSEMC function is used to initialize SDRAM, but after I call BOARD_InitSEMC, I find that I cannot read and write SDRAM. I think there are some problems with my initial configuration. Could you please help me check? I modified it by referring to the DEMO instance evkmimxrt1170_semc_cm7 because my SDRAM is different from the development board.
Here is my initial configuration
Besides the initial configuration, do you need to pay attention to anything else
Question 2: In addition to calling the initialization function, you can also initialize SDRAM by configuring DCD through the configuration tool. Do you have a DCD configuration file for W989864G6KG? Can you provide me with a,
jingpan
ywjack
This configuration should be correct。
I mean do you need to configure anything else besides initialization
jingpan
Hi @ywjack ,
Yes, if you test SEMC example, all above is enough.
In some other examples, you must enable  "USE_SDRAM" definition and determine which part should re-locate to SDRAM.
Jing
