RT1170 Max Supply Current Calculation
matthewkemp
In Section 4.1.4 Maximum Supply Current of the RT1170 Datasheet, the equation for Imax = N x C x V x (0.5 x F) is listed where F is the clock rate in Hertz.  However, what clock rate should be used?  (i.e. core frequency, bus frequency, or something else)
FelipeGarcia
Hi Matthew,
In general, you can use "maximum" frequency for each interface. However, please note that this formula is just rough estimate.
Felipe
- We are following threads for 7 weeks after the last post, later replies are ignored. Please open a new thread and refer to the closed one, if you have a related question at a later point in time.
