RT1170-EVK rev C4 schematics
1,051 次查看
mastupristi
Senior Contributor I
downloadable from site (https://www.nxp.com/webapp/Download?colCode=MIMXRT1170-EVK-DESIGNFILES ) there is only revision C3 of the schematics SCH 32171, but I have C4. For example, I have one more switch than the schematic (SW3).
Where can I find the SCH 32171 rev C4 schematics?
best regards
Max
标记 (4)
975 次查看
Pavel_Hernandez
Hello, the reset button is on page 26 and is the same, for example as the RT1064.
破坏者
RT1064
Let me know if you need more information.
Pavel
4 回复数
1,021 次查看
Pavel_Hernandez
Hello, I review your information the schematic is not available at this moment, but you totally can refer to the Rev C3, as the schematic and the PCB is totally the same, just one point to the C4:
FXOS87OO is EOL, so rev C4 take is as DNP, others are totally the same.
Schematic just use C3.
Pavel
991 次查看
mastupristi
However ,I cannot find the circuit diagram related to the SW3 button.
It says in the user guide that it has to do with the POR
But I need to know exactly how this SW3 is connected with the POR pin, such as are there pull ups or capacitors? What values?
best regards
976 次查看
Pavel_Hernandez
破坏者
RT1064
Pavel
1,038 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Pavel
