RT1060 - SDRAM Initialization Script
773 次查看
pauricacre
Is there an initialization script for debugging SDRAM in MCUXpresso using CMSIS-DAP on the RT1060? I cant find one. I'm unable to debug my EVK when my application is set to run in SDRAM.
752 次查看
victorjimenez
You can download the script from the following link:
Overview of using the MIMXRT1050-EVK(B) with MCUXp... - NXP Community
Although the script says that it's for the RT1050-EVKB, the RT1060-EVK has the same SDRAM. The pdf document explains how to use this script.
Victor
753 次查看
victorjimenez
Victor
