I hope you are all ok.
If you look at the RT1020 consumer datasheet:
i.MX RT1020 Crossover Processors for Consumer Products, Rev. 1, 04/2019
Page 43
Section 4.5.1.2.2 SEMC input timing in SYNC mode
With SEMC_MCR.DQSMD = 0x1, the TIS Data input setup parameter is 0.6.
I.e. The data has to be present on the bus 0.6ns before the RT1020 can clock it in.
If you look at a typical data sheet for a 166MHz SDRAM device, for example: the ISSI IS42S16160J-6. (Data sheet attached: 42-45S83200J-16160J.pdf)
The Access Time from Clock is 5.4ns. (Probably a JDEC spec.)
So 5.4 ns to present the data, leaving only enough time (0.6ns) before the RT1020 reads it in.
5.4 + 0.6 = 6ns. 166Mhz is a 6.02ns clock cycle. So practically zero margin.
What am I missing here? No one would accept a margin of zero, and the eval board seems to work, so I know I am missing something.
Or is there an adjustment/register that could help here? I couldn't see anything obvious in the reference manual or the semc/sdram demo.
Many thanks.
Hi ,
5.4 ns is the maximum limit time of the Access Time From CLK, in reality, it definitely is less than 5.4 ns.
From the experience, slow down clock frequency is a good way to assure time configuration meets its characteristic requirements.
TIC
