Query related to Power consumption is DMA
搜索替代
720 次查看
suhel_mulla
We are using NXP i.MX RT 1052 controller.
We already know that DMA is used for parallel processing and to improve overall processor performance.
But, we are trying to understand whether DMA can be used to minimize current consumption or not.
My question is as below -
Consider the below 2 cases,
  1. SPI DMA is used to transfer SPI data between memory and SPI transfer registers, CPU(Cortex M7 core) is in sleep mode.
  2. Normal SPI is used (SPI DMA is not enabled) to transfer the same amount of data between memory and SPI transfer registers using CPU.
For these 2 cases, in which case, the current consumption will be more?
Also, please provide if any analytical document is available for this.
标记 (5)
715 次查看
jeremyzhou
1) My question is as below -
Normal SPI is used (SPI DMA is not enabled) to transfer the same amount of data between memory and SPI transfer registers using the CPU.
-- Case 2 will cost more power consumption.
And there's an article that explains the DMA's advantage and hopes it can help you.
Hope it helps.
TIC
710 次查看
suhel_mulla
Thanks for the answer and sharing the article. It will solve my query.
714 次查看
suhel_mulla
Thanks for the answer.
Can you share link of the article which explains it?
716 次查看
jeremyzhou
Hope it helps.
TIC
