OTP programming for imxrt1011
1,176 次查看
Sarajia
Hi sir,
Would you mind sending me the userguide for OTP programming for imxrt1011?
I found  section "Software Write Sequence" which is mentioned in 23.6.1.7 of https://cache.nxp.com.cn/secured/assets/documents/en/reference-manual/IMXRT1010RM.pdf?fileExt=.pdf
标记 (1)
8 回复数
597 次查看
irfanaspl
I think this answer will help you Programming NXP i.MX RT OTP fuse with west
Irfan worked as a reporter for TechCrunch since August 2011. She joined the company after having previously spent over three years at SMSala Bulk SMS Provider. Irfan worked in I.T. across a number of industries, including banking, Marketing, retail, and software.
1,111 次查看
Gavin-liu
MXP-MCUBootUtility tool excellent !
there is a issue for the BEE encryted, 1051.
Flash my bin file in "Dev usigned image boot", the board can power on and work as normal.
but fiash the same file in  BEE "encrypted imaged boot" mode, can not power on.
could you help find that wrong operation and other point......
1,093 次查看
jay_heng
You need to enable below EncryptedXIP bit - BOOT_CFG1[1].
1,088 次查看
Gavin-liu
Sorry for my post.
the XIP  have been seeting in efuse. please help double check.
thank you in advance!
1,084 次查看
jay_heng
Please check BT_FUSE_SEL bit, refer to 1.2.2 and 1.2.3 sections in https://www.cnblogs.com/henjay724/p/9034563.html
1,071 次查看
Gavin-liu
Thnak you for the quick reply, follow your comments.
serial NOR flash have been mounte on the PCBA, and below  is my setting:
1. internal boot mode,(0010)
2. BT_fuse_SEL=0 in fuse
3. The detail info of Boot_CFG pin is below PIC.(Due to the board can not power on. I have tried to change the"BT_CFG[1]" to High and enbale the XIP. At last, the board still can not power on .)
Till now, my board is ok in "Dev usigned image boot "mode, and fail in "encrypted imaged boot" mode.
the boot CFG seeting if related this case?
1,037 次查看
jay_heng
You can do some tests to verify it is app issue or BootROM issue
Below two blogs may help you:
https://www.cnblogs.com/henjay724/p/14446183.html
https://www.cnblogs.com/henjay724/p/14479276.html
1,151 次查看
jay_heng
There are three ways to burn OTP
1. NXP-MCUBootUtility tool
2. SDK demo: \SDK_2.11.0_EVK-MIMXRT1010\boards\evkmimxrt1010\driver_examples\ocotp
3. flashloader package and blhost.exe tool, refer to https://www.cnblogs.com/henjay724/p/9108176.html
