MfgTool for linux?
1,018件の閲覧回数
tamir_michael
I have noticed that the linux branch of the git repository of MfgTool (https://github.com/NXPmicro/mfgtools.git) is presumably no longer maintained (last change was in September 2018, while some commands cause segmentation faults and other forum threads suggest is does not work). We plan to move from a i.MX RT1064 to a i.MX RT1060, and so we must be able to generate bootable external flashes using a linux machine. How do you suggest we proceed? "elftosb" seems to work, at least at first glace.
Thanks in advance.
タグ(2)
946件の閲覧回数
jeremyzhou
Hi Tamir Michael ,
The MfgTool seems like a tool that consists of UI interface and Blhost, in actually, it invokes Blhost to program the image on target memory devices connected to i.MX RT device.
So I'd like to suggest you use the Blhost tool directly to program the bootable image to the external flash.
I've attached the Blhost User's Guide for you to refer to.
TIC
2 返答(返信)
947件の閲覧回数
jeremyzhou
Hi Tamir Michael ,
TIC
946件の閲覧回数
tamir_michael
OK, thanks. I'll look in the source code to see what's going on.
