IMXRT1176 LPADC2 Support
482件の閲覧回数
Ykciv
We used lpadc_polling example to read the data in ADC1. Its working fine.
But we need to read ADC2 channels for our project, If I change the base address of ADC1 with ADC2 its not working.
Can you please share any working example for ADC2?
5 返答(返信)
455件の閲覧回数
Andy_h
i have a similar problem. While using the adc_etc interrupt test, just changing the ADC base doesn't work. Do i need to do more config changes?
452件の閲覧回数
jingpan
DEMO_LPADC_BASE definition from LPADC1 to LPADC2, and DEMO_LPADC_USER_CHANNEL to 4. That's all what I did on the polling example. But if you test the interrupt example, you should also modify the interrupt related code.
Jing
469件の閲覧回数
Ykciv
Im using 6 channels in ADC1 and 1 channel in ADC2. Shall we configure the same trigger to individually read all channels?
460件の閲覧回数
jingpan
Hi @Ykciv ,
No, ETC has 8 ext_hwts. You have enough trig channels to both of two adc.
But of course you can use one trig source to trig all 7 channel by trig chain mechanism.
Jing
476件の閲覧回数
jingpan
Hi @Ykciv ,
Just change DEMO_LPADC_BASE definition from LPADC1 to LPADC2 is enough.
I tested on RT1170 EVK, define DEMO_LPADC_USER_CHANNEL to 4 (because LPADC2 CH0 doesn't pin out on the board). It works fine.
Jing
