Hi community ,
Im currently working with the IMXRT1170EVK ,the board has gone to sleep now im unable to wake it up.
How do i flash some other program into the Flash .
Is there a way to use Secure provision and flash an image into the EVK .
PROBLEM .
1)The board has gone to sleep unable to wake up (Wake up pin has been changed ,no other means to wake up).
2) Need to use the EVK ,how to make sure its in default condition .
3)Steps to Flash the code or steps to use Secure provision to achieve the above task .
Details :
Board :MIMXRT1170-EVK
Thank you and regards
UJWAL
Thank you for contacting NXP support.
I understand the concern can you please help me with some extra details in order to find a solution to your case:
Please help me with this point in order to proportionate a solution.
