How to use secure provisioning tool to generate image for octal flash # Macronix MX25UM25345G?
This device is not listed in the pre configured options.
Do we need to use a custom FCB? thanks!
Hi @nickwallis
Yes, you can create your customized FCB with the our Secure Provisioning Tool (SPT) . Below an example
https://www.nxp.com/docs/en/user-guide/MCUXSPTUG.pdf#page=33
Below snapshot, shows that you can customize, test and create your own FCB with the SPT.
Also, you can use the MCUBoot Utility ( developed by our colleague Jay Heng). To genereate a bootable image for your memory. As you can see in the below snapshot, here is a generic model of your flash selected.
Diego
