Any possible ways to view PHY registers in MCUXpresso IDE
monisha_d
Hi there,
We are having a custom board of IMXRT1024 series connected with PHY KSZ8081RND. With the help of peripherals view in MCUXpresso IDE, we are able to look at the chip's registers status. Also, we are aware that these registers of the PHY transceiver are mapped to a particular address in MCU. But is there any way to look at the status of the PHY registers in the IDE by that mapped address?
Monisha
ENET registers of MCUENET registers of MCU
Tags (2)
kerryzhou
Hi @monisha_d ,
  As you know, the PHY is not the RT on chip IP, so it can't be checked directly.
But you can read the PHY register through the code, and use the printf to print it out to check it.
Wish it helps you!
Kerry
monisha_d
Hey Kerry,
Yes, I did what you told and its working.
Thanks for reaching out.
Monisha
kerryzhou
Hi @monisha_d ,
Wish it helps you!
Kerry
