Hi all,
We are going to use SEMC as SRAM-I/F(ASYNC non-ADMUX w/ WAIT) to connect to FPGA.
Please tell me the behavior of the UB/LB signals.
Can you provide me with a timing diagram showing those behaviors?
BR,
George
Solved! Go to Solution.
Hi George,
I received an update, you can take as reference see the LB#/UB# signals in ASYNC SRAM write in Non-ADMUX address mode.
Felipe
Hi George,
These signals are Upper and Lower Byte select pins. SRAM will read or write upper or lower data byte depending on this signals. We do not have timing diagrams including these pins but you can find more information of this in your specific memory datasheet.
Felipe
- We are following threads for 7 weeks after the last post, later replies are ignored. Please open a new thread and refer to the closed one, if you have a related question at a later point in time.
Dear @FelipeGarcia
The device that connects to the RT1175 is an FPGA.
We have to configure the FPGA according to the RT1175 I/F specifications.
Therefore, we need to know the cycle-based signal transition.
Other signal timings seem to be variable by the registers, but it remains unclear where the signal transitions occur for UB and LB.
For example, in the following mode :
At what timing in this figure the UB and LB signals transition?
And where is it when read ?
BR,
George.
Hi George,
Unfortunately, we do not have timing diagrams including these signals. However, just for reference you can check SRAM datasheets for example: https://www.issi.com/WW/pdf/65WV25616ALL_BLL.pdf
There you will find more info about timing and behavior of these signals.
Felipe
Hello @FelipeGarcia
The documentation you presented to me allowed me to understand the behavior of UB/LB.
I think you can guarantee that UB / LB is valid during green period I added in red.
Is my understanding correct?
BR,
George
Hi @george,
Could you please provide what was the thinking behind this timing diagrams? Please be as detailed as possible.
Felipe
Hello @FelipeGarcia,
Sorry for the late reply.
The UB/LB I added may have been too extreme.
It may be necessary to extend the valid fields backward by one semc_clk.
My thoughts are as follows.
First, Write timing:
SRAM needs to capture UB/LB-gated DATA at WE# rising edge.
I think UB/LB needs setup and hold at WE# rising edge.
Second, Read timing:
SRAM needs to control the DATA output with UB/LB and OE, which requires setup and hold for the internal rxclkn rising edge.
Please tell me the valid period for which you can guarantee.
BR,
George
Hi George,
To give you an update. We are still trying to get further information from IP owner. Once I get more information I will post it here.
Felipe
Thank you for your sincere response.
I will continue to wait for your reply.
BR,
George
Hi George,
Felipe
Thank you for the update.
In other words, we understand that UB#/LB# is Low-Active between AS and WEH in the internal state.
George
Hi George,
I will check internally if we have any information about this.
Felipe
