Hello Ben,
I'm not sure that I understood correctly your question, so please correct me if I'm wrong. You can download the software of that application note from the following link. If with your question you mean how long will it take you to migrate this example to use your custom board instead of the evaluation board, then it won't take you much since you only need to change the pin configurations.
Victor
