iMXRT1064 with latest Emwin
1,073 次查看
anujtanksali
Am using iMXRT1064 controller and using Emwin for GUI. I came to know that Emwin ver 6.14 is released but could not find this library on NXP emwin web page. Can you please share the latest emwin ver 6.14. library for use with iMXRT1064 device.
I was able to download 6.10 libraries from NXP emwin web page but need ver 6.14 library
I plan to use Keyboard widget in my project and observed that this widget is added in Emwin ver 6.14.
标记 (1)
989 次查看
jeremyzhou
Hi  Anuj Tanksali,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
I'm afraid that the v6.14 is unavailable to download now. And you need to contact the Segger if you want to use the lasted version.
TIC
989 次查看
anujtanksali
Hi jeremyzhou‌,
Thanks for the reply.
I wanted the emwin library file to use on iMXRT1064 device. As this is a NXP device i think it should be provided by NXP
I will check with segger but when will this be available from NXP.
Anuj
