iMXRT1010 svd file
iMXRT1010 svd file
2,029 次查看
gfisys
Anyone knows where I can get the SVD file for the iMXRT1010 chip?
6 回复数
1,985 次查看
Masmiseim
Senior Contributor I
1,979 次查看
gfisys
Thanks so much! I appreciate it.
2,018 次查看
jingpan
Hi @gfisys ,
You can extract the CMSIS-SVD files from the NXP MCUXpresso SDK: they are just using an .xml extension instead of the standard .svd one.
Jing
2,015 次查看
gfisys
Thanks for the tip @jingpan
I searched the SDK folder and subfolders, but the only xml file that looks like an svd file is this one: 'MIMXRT1011xxxxx_manifest_v3_10.xml'. I tried to load this file into my Segger embedded studio IDE, but it doesn't seem to recognize it as a proper SVD file. Is that the correct file?
1,968 次查看
jingpan
Hi @gfisys ,
You can find it in SDK_2_13_0_MIMXRT1020-EVK\devices\MIMXRT1020.
Jing
1,996 次查看
gfisys
@jingpan can you tell me the exact location inside the MCUExpresso SDK where the xml file you mentioned resides? Cause I can't find the file. Or, if you have the file can you send it to me? Thanks.
