i.mx rt1050 booting from LPSPI
christiangradl
What are the exact bootmode/pins settings for booting via LPSPI?
in the TRM table 8-8 there is no entry about this.
Above there stands
   The chip supports these boot flash devices
       Serial NOR/EEPROM boot via LPSPI
christiangradl
OK, thanx, that info helps.
Hi Christian
pinmux settings are given in Table 8-1. ROM Bootloader Peripheral PinMux
i.MX RT1050 Processor Reference Manual
Boot mode only using fuse mode as shows Table 8-35 (there is no GPIO override mode),
fuse selections are given in Table 5-9. Fusemap Descriptions i.MX RT1050 Processor
Reference Manual
https://www.nxp.com/docs/en/reference-manual/IMXRT1050RM.pdf
christiangradl
in table 5-9 there is no definition for booting woth LPSPI. Register 0x450[7:0]???
I can select the LPSPI chipselect register 0x6D0, but how can i select the boot device for LPSPI,
as described in chapter 8-2
    The boot ROM supports these boot devices:
   â€¢ Serial NOR Flash via FlexSPI
   â€¢ Serial NAND Flash via FlexSPI
   â€¢ Parallel NOR Flash via SEMC
   â€¢ RAWNAND Flash via SEMC
   â€¢ SD/MMC
   â€¢ SPI NOR/EEPROM via LPSPI
boot ROM uses it as recovery device using one of the LPSPI ports,
please check description in sect.8.10 Recovery devices
christiangradl
