i.MXRT1050 EVK - SDRAM support with Zephyr
1,764 次查看
treto
I'm using the i.MXRT1050 EVK with Zephyr RTOS. I'm running into an issue with my data size as I need a relatively large frame buffer that won't fit inside the internal SRAM.
Is there support (or a plan) to support SDRAM with Zephyr RTOS?
Lukasz
标记 (1)
1,512 次查看
Carlos_Musich
Hi Lukas,
As mentioned we do not yet support RT1050 SDRAM in Zephyr. The immediate goal is to enable the Hyperflash, and after that SDRAM will be scheduled but I’m not sure of the timeline yet.
Since Zephyr is an open source project like Linux, customers can contribute features if they need them sooner. There is also support available through the Zephyr community on the public mailing lists.
https://www.zephyrproject.org/developers/how-to-contribute/
Carlos
NXP Technical Support
1,513 次查看
Carlos_Musich
Hi Lukas,
Carlos
1,512 次查看
Carlos_Musich
Hi Lukas,
to my knowledge there are no plans. But I will check and if I find something I will let you know.
Carlos
