I need source code for this application. I dont see it in the SDK. Can I have a copy of this source code?
SW\src\boards\evkmimxrt1060\use_case\firmware_swap\.
Solved! Go to Solution.
To provide the fastest possible support, I'd highly recommend you to refer to the application note which introduces how to use the flash
remapping function and the attached code is the related source code.
TIC
TIC
