blhost cannot establish a connection based on the USB path
594 次查看
Vinos
Since I want to simultaneously connect multiple RT1170 USB devices to a single computer for concurrent production, using blhost requires connecting via USB path.
The relevant connection examples can be found on page 10 of the document below
https://www.nxp.com/docs/en/user-guide/MCUBLHOSTUG.pdf
However, even after querying the USB path through this step, I still cannot establish a connection successfully.
Prompt as shown in the following image. How can I establish a connection through the USB path?
588 次查看
Vinos
After my test, it is possible to connect to the device in this way, but it is necessary to try sending commands multiple times before the command finally returns success.
Why is there a high probability of command execution failure?
