Why is the lpspi_loopback example failing?
2,149件の閲覧回数
alex_duh
I'm running the lpspi_loopback example program on an RT1060, and have wired together pins J24-4 and J24-5 (MISO & MOSI), but the masterRxData[] array is filled with zeroes and the test fails. Have I overlooked any configurations or settings?
タグ(2)
2,036件の閲覧回数
kerryzhou
Hi Alex Duh,
  Thanks for your information.
  Do you following this board settings?
Board settings
Remove the resistor R334 and weld 0Ω resistor to R278,R280.
This is very important.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
3 返答(返信)
2,036件の閲覧回数
kerryzhou
Hi  Alex Duh ,
   Which RT1060 code you are running now, the SDK?
  I didn't find lpspi_loopback example in the newest SDK.
So, I suggest you download the newest SDK, and test the SDK lpspi code, it works OK.
The SDK can be downloaded from this link:
Wish it helps you!
Kerry
2,036件の閲覧回数
alex_duh
Hi Kerry,
I think I am using the newest SDK. The project is is in demo_apps, the full path is /evkmimxrt1060_lpspi_loopback.
2,037件の閲覧回数
kerryzhou
Hi Alex Duh,
Board settings
Wish it helps you!
Kerry
