Why eDMA not work? RT1170EVK (LPADC to memory)
2,172 次查看
auftrag2021
HW: RT1170EVK
Target: move the RESFIFO from LPADC1 to dstAddr
Configuration in eDMA:
Configuration in LPADC1
start LPADC1 per SW in Main()
LPADC_DoSoftwareTrigger(LPADC1, 1U);
The problem is, the callback from eDMA function was never called in my application. Why?
So far as I understand, I trigger the LPADC1 per SW, after the watermark is running out, the LPADC1 trigger the DMA request, then the DMA get the result from LPADC1->RESFIFO, because I set the Minor and Major both as 4-Bytes, the eDMA should activate the callback after 4-Byte is transfered, right? where do I do wrong?
p.s. I extra tested the eDMA alone with SW trigger (EDMA_StartTransfer(&DMA0_CH0_Handle);), the callback function worked pretty well. The eDMA itself has no problem.
2,111 次查看
auftrag2021
thanks for your attention.
the issue was solved, but not in your way. the DMAMUX was correctly configured.
The problem was, I did set the watermark as 1, when I change the value to 0. It's fine to trigger the callback function from eDMA
5 回复数
2,127 次查看
Hui_Ma
Sorry for the later reply.
Besides of initialize LPCADC1 and eDMA module, it also needs to config the DMAMUX.
Please refer below code just an example for your reference:
Wish it helps.
Mike
2,112 次查看
auftrag2021
1,017 次查看
akhil__
Could you please share this file for reference? I'm facing some issues while configuring LPADC using DMA. Having access to the file would greatly assist me in understanding the correct configuration procedure and resolving the difficulties I'm encountering. Any additional guidance or insights you can provide on LPADC configuration with DMA would be greatly appreciated. Thank you for your assistance."
1,005 次查看
auftrag2021
I am not using RT1176 for a long while
here is sth. I found a few years ago about the eDMA config tools problem
https://community.nxp.com/t5/MCUXpresso-Config-Tools/eMDA-config-tools/m-p/1432103#M1363
due to NXP staff reply, there are some bug in the MCUxpressor for the eDMA config tools
if you want your eDMA work properly, strictly follow the user manual instruction,  don't blindly trust the config tools
2,106 次查看
Hui_Ma
Thank you for the updated info.
Mike
