Using VGLite with custom Display
915件の閲覧回数
Bedair
    I'm currently building a new board based on i.MX RT1176 microcontroller to driver a custom Display. I managed to communicated with display via MIPI-DSI interface to initialize the display but when I try to use VGLite to show images on the display I didn't work.
    My question is how to start debugging such issue? and what may be the reason for such issue?
862件の閲覧回数
Bedair
Issue now fixed, it was because of the clock configuration.
2 返答(返信)
863件の閲覧回数
Bedair
900件の閲覧回数
CarlosGarabito
hi @Bedair The most probably is that your connection with the display is wrong, i suggest that check our design as reference for your connection with the LCD
https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true
Have a good day
