- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Can anyone help me out on this issue. I am trying to debug baremetal firmware in i.MXRT1189 evk and each time i am getting the error as per the image attached with this. i am able to debug successfully on cm7 core but not on cm33 core.
#i.MXRT1189
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @vilas_shetty ,
Please check my test result:
You can see the cm33 project can be entered.
SW5: 0100
And the debugger is using the on board CMSIS DAP debugger, J53.
Please try it again, thanks.
If you still have issues, you even can refer to my document:
chapter 2.3.2 RT1180 AVB switch,
Use the mcubootutility to download the cm33 code.
The code can try the mcubootutility attached cm33 code:
Wish it helps you!
if your question is solved, please tell me to close this case, and help me to fill the feedback as resolved, thanks.
Any new issues, welcome to create the new case.
Kerry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @vilas_shetty ,
Thank you for your interest in the NXP MIMXRT product, I would like to provide service for you.
Do you try the SDK demo code, eg, the helloworld cm33 project, whether that code downloading works or not?
BTW, please tell me your side information:
1. mimxrt1180-evk reversion number
2. Your used SDK version, please also try the helloworld or the led_blinky project, cm33,
If you still have issue about it, please kindly let me know.
Kerry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am still facing the same error even after i tried with helloworld cm33 demo project.
Board details:
mimxrt1180-evk reversion number - SCH-50577 REV C3,
700-50577 REV C
SDK version - 2.16.000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @vilas_shetty ,
SW5: 0100
Wish it helps you!
Kerry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes i got the same solution from nxp technical team and the boot switch position was 0001 initially which was a serial downloader. Thank you very much for your support. but i think some configuration is still need to be done because i am getting the same error when i create a new c/c++ project for both cm7 and cm33 cores.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @vilas_shetty ,
Please give me more time, I will help you to check it tomorrow, as I don't have the board on my hand right now, I will find board and test it on my side tomorrow, then give you updated information.
Thanks a lot for your understanding.
Kerry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you and will be waiting for your response.
