- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
I setup RT1060 EVK and wi-fi module EVK-JODY-W2 follow the UM11441.
But I can't find the marco in app_config.h as Table 22 in UM11441.
( My example code is "evkmimxrt1060_aws_shadow_wifi_nxp" )
app_config.h as below:
Table22 in UM11441 as below:
So could you provide JODY-W2 example code or marco to me, thanks.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Daniel,
I found the issue on EVK-JODY-W2 and my shareing as below:
1. EVK-JODY-W2 need 1A current when FW download so I connected a USB adapter.
2. EVK-JODY-W2 power on first and then RT1060 EVK.
Sofar I can exceuting the AWS demo and no any porblems.
Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @scarletlee ,
My name is Daniel and I will be happy to help you.
Which SDK version are you using?
I imported the AWS example from the 2.12.1 SDK and I found the EVK-JODY-W2 macro as shown in the image below.
Could you please try it with the latest RT1060 SDK? You can find it here.
I hope this helps.
Best regards, Daniel.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Daniel,
Thanks for your reply.
My SDK version is same with you ( 2.12.1 ) but my AWS sample code not found the EVK-JODY-W2 marco.
The screenshot as below :
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Daniel,
Update my status : I re-installed the SDK and then I found the EVK-JODY-W2 marco in AWS shadow wifi example.
But I can't connect to the wi-fi ap my modify steps as below:
1. Modify wi-fi board to EVK-JODY-W2 in app_config.h
2. Input Endpoint, Thing name, SSID and PWD.
3. Copy my aws_clientcredential_keys.h to include folder
By the way, I confirmed my aws_clientcredential_keys.h, AWS Endpoint and Thing name are work on the aws_shadow_enet exmaple.
4. The terminal show msg : sd_wifi_init failed, detail as below :
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Which EVK version do you have? Is it MIMXRT1060-EVK or MIMXRT1060-EVKB?
Could you please try another WiFi example (i.e. wifi_cli) to see if the initialization problem still occurs?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
SDK Name : SDK_2.x_EVK-MIMXRT1060
SDK version : 2.12.1 (632 2022-09-26)
I tried the evkmimxrt1060_wifi_cli example and results is "FW ready registers not set"
My screenshot as below :
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Which RT EVK version do you have? I'd like to know this because in some of your images you are showing me the SDK for both versions, MIMXRT1060-EVK and MIMXRT1060-EVKB. And according to UM11441, Table 2, it seems that EVK-JODY-W2 is only supported in RT1060-EVK.
Please take a look to the readme (readme_modules.txt) file in the example and verify the jumper settings in the module. Also, could you please take a look to the EVK-JODY-W2 User Guide? There is a link in the same file to download it.
I hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Daniel,
