RT1021 flashloader: debug_uart_print() is missing
875 次查看
JamesNgo
I enabled debug trace on UART1 as an option in flashloader. There's a API debug_uart_print() referenced in debug_util.c file but does NOT exist I need your help to locate it:
767 次查看
Miguel04
Hi @JamesNgo
Sorry for the late reply, I've been reviewing the issue and this is what I was able to find:
On the RT1021 flashlaoder example the body of the function is missing, however I found it on the RT1060 SDK, see image bellow.
This is from the hardware_init_MIMXRT1062.c file, I'll report this issue with my team, do you need this function or you have the inquiry where is the "body"?
Thank you for your contribution.
Best Regards, Miguel.
847 次查看
Miguel04
Hi @JamesNgo
Are you refering to the body of the function or where is it declared?
840 次查看
JamesNgo
The "body" of the function is missing.
768 次查看
Miguel04
Hi @JamesNgo
