I'm trying to create a HID device using the MIMXRT1050, and would like to use an interrupt endpoint to send asynchronous data. Does the i.MX RT 1050 support a USB interrupt endpoint that can send more than one transfer per microframe?
The USB 2.0 specification mentions "high-speed, high-bandwidth" interrupt endpoints in Sections 5.9 and 5.9.1. However, the section on endpoint descriptors in the i.MX RT1050 Reference Manual, on page 3167, in Table 54-57, it says that "Non-ISO endpoints must set Mult='00'.", and as far as I understand, there is no field in the qTD used by the interrupt endpoints to allow for multiplier overrides.
If I wanted to get multiple transfers per microframe over the same endpoint, would I then have to use an isochronous endpoint and abandon HID?
解決済! 解決策の投稿を見る。
Hi Myles
yes this is correct understanding.
right.
Hi Myles,
How to enable Mult transactions per microframe?i had tried to set bit 12...11 as 10 of wMaxPacketSize,but looks like it no work properly.Can you give me some advice?
Nick.
Hi Myles
right.
