Is there a way to connect HDMI display to imxrt1050
1,515件の閲覧回数
morganRo
Hi everyone,
Is there a way to connect HDMI display to imxrt1050-evk ?
Any devBoard? Convertor?
M.
1,501件の閲覧回数
kerryzhou
Hi @morganRo ,
  As I know, you can find the convert chip which support the TTL->HDMI, then you can use that convert board to connect to the RT105X chip, RT105X can't support the HDMI interface directly. For the convert chip, you need to find it by yourself, as I know, NXP don't have that chip.
Wish it helps you!
kerry
5 返答(返信)
1,503件の閲覧回数
morganRo
And is there any solution for example to convert TTL Interface to HDMI? Existant board?
1,502件の閲覧回数
kerryzhou
Hi @morganRo ,
Wish it helps you!
kerry
1,497件の閲覧回数
morganRo
ok, thanks for your time.
Best Regards
1,488件の閲覧回数
kerryzhou
Hi @morganRo ,
   You are welcome!
   If your question is solved, please help me to mark the correct answer, just to close this case.
  Any new issues, welcome to create the new question post.
Kerry
1,508件の閲覧回数
kerryzhou
Hi @morganRo ,
   As I know, the RT1050 don't have the HDMI module, it can't support the HDMI interface.
  You can use the I.MX series, that contains the HDMI module.
Wish it helps you!
kerry
