IMXRT1064 SEMC - SRAM SYNC CLOCK Pins
789 次查看
Lukas_Frank
Senior Contributor I
Hi Dear Authorized,
I am asking this question to be sure about SYNC Mode Output Pins. I am looking for pin ouputs related to SEMC_CLKX0 and SEMC_CLKX1 for SRAM mode. We have mentioned about the below informations related to them:
  • SEMC_CLK5 related PAD is  GPIO_EMC_40 or GPIO_SD_B0_02 with MUX_MODE ALT9
  • SEMC_CLK6 related pad is GPIO_AD_B0_11 or GPIO_SD_B0_03, both MUX_MODE is ALT9
I am getting below error when I configure it from ConfigTools for "GPIO_EMC_40" pin. There is no rising errors for "GPIO_SD_B0_02", "GPIO_AD_B0_11", and "GPIO_SD_B0_03".
Could you please help me about the error?
Thanks and Regards.
716 次查看
Pavel_Hernandez
Hello, I'm following your case and I do the test in the IDE, I suggest deactivating the RDY to use the ALT9.
Pavel
773 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me review your information and when I have more information, I will contact you.
Pavel
