How to connect two codecs to a IMXRT processor
240 次查看
LuigiV
I have to connect a four channels codec (AK4619) to a IMXRT processor, for example the IMXrt1011 (I have the evaluation board) or the IMXrt1021...IMXrt1062..., or two codecs to a IMXRT processor.
May you help me how to do it and if does exist a code example ?
Thank you.
Luigi
215 次查看
Omar_Anguiano
Please refer to this example to use the multichannel feature of the SAI module: Using Multi-Channel Feature of SAI (nxp.com)
From RT1020 SAI1 supports up to 8 channels.
Omar
216 次查看
Omar_Anguiano
Omar
