Hardware trigger with ADC2
2,720件の閲覧回数
kurt_staubli
As others I struggle with hardware trigger of ADCs.
My base was NXP's example adc_etc_hardware_trigger_conv. It works as expected.
Next I tried to do the same but use ADC2 instead of ADC1. I  didn't get any interrupts. I used trigger 4 instead of trigger 0 and I added an interrupt handler for ADC_ETC_ERROR. I received periodically ADC_ETC_ERROR but no  ADC_ETC_IRQ0/1 as expected.
5 返答(返信)
2,551件の閲覧回数
jeremyzhou
Hi Kurt Staubli,
the opportunity to serve you.
To provide the fastest possible support, I'd like to suggest you refer to the post which is a similar question on our NXP community.
i.MXRT1060 ADC external trigger (ADC_ETC) for ADC 2
TIC
2,551件の閲覧回数
kurt_staubli
Hi jeremyzhou Mitarbeiter
Thank you for your answer.
did not help me, since its solution (use XBAR1, instead of XBAR0) was already implemented in the original example adc_etc_hardware_trigger_conv and I did not change it.
Kurt
2,551件の閲覧回数
jeremyzhou
Hi Kurt Staubli,
Thanks for your reply.
I was wondering if you can share a compile-able demo that can replicate the issue, as I'd like to do some testing by myself.
TIC
2,551件の閲覧回数
kurt_staubli
I have solved the problem.
The orignial example is adc_etc_hardware_trigger_conv. I have just the changed files in the attachment. As hardware I am using EmbeddedArtist's RT1060 Evaluation board. The difference to NXP's evaluation board is that EA's board has much more IOs for the user.
Kurt
2,254件の閲覧回数
ohmjke
Thank you @kurt_staubli
It helped me with the same problem on RT1024.
Solution - change the default value of enableTSCBypass from "true" to "false";
